was thinkin of getting a sealer or else gettin the windows tinted and sealed and sorted! wot everyone think?
window problem
cruisin_chris
window problem
drive a 1.4cl and got electric windows, everythin works 100% and replaced the pollen filter which makes great different with air circulation but still have stemed up windows, not as bad after new pollen filter but still steams and hard to get rid of! any ideas?
Fogged up windows (beyond normal levels) is usually the result of water in the car. Have you checked for leaks in the door seals? Front door seals are notorious for leaking.
Try the boot seal as well and check under the carpets (all of them) for wet spots. Look in the spare wheel well too, water tends to gather there. Alternatively, you could have a front wind shield that's leaking, we had this on one of our cars at one point. Refitting the window helped.
- bstardchild
- Moderator
cruisin_chris
