VW sport suspension + eibach 30 mm pro-kit: is it worth it?
logistix
Post by logistix »
hello everyone,
i've been looking around for different suspension options and haven't been able to find a decent product available for my TDi. i don't want to invest in coilovers as they are expensive and my driving style does not really require their benefits. so please, can anyone with the sport pack in their polos compare their vw sport suspension to stock suspension, as i'm considering going for those dampers? also, how would the eibach pro-kit pair up with them?
thanks in advance
Yetkin
Joy
Post by Joy »
That would be a proper setup. I have no doubt that you will enjoy the ride.
Vitorino
Post by Vitorino »
The Eibach springs from vw votex are good and you will feel it but I recomend to you to start thinking in change the shocks. Because the springs are lower than the dispalcement of the shocks, and they will start to work badly.
I mounted the eibach springs in my polo an it has the sport suspension from vw original (that means between 5-10 mm lower) and the Eibach springs are 25-35 mm lower (it depends on the weight).
I'm thinking in a Sachs suspension kit it would be better, or only buy Sachs shocks 30 mm lower than oem shock absorbers.
