Rightclick KE60W Remote Central locking onto a POLO 9N3 PICS
Hi there, I recently purchased a rightclick system to convert my central locking to remote. On the install guide it says it all takes place in the driver side door but i beg to differ after reading the DIY guide on fitting the same kit to a mk5 in the DIY guides. Here are some pictures of the wireing under my dash as i am not sure which ones to use. I am asking if anyone has fitted the same kit to this car could give some advice many thanks in advance
There are some pictures from inside the door card - Which i cannot get back on properly ??? Any help !"!!!!!!
And then under the dash drivers side
thanks guys
thanks guys
found this might be of some help even tho its for a 6n2
http://www.dubclique.com/forums/viewtopic.php?t=77
a deadlock is a secondary locking device which makes it more difficult to break into the car. when you lock the car, you should hear two "clicks" one locks all the doors second deadlocks themchinnus wrote:well so far i have bodged it onto the interior lock / unlock switch on the drivers side door it works ok but does not deadlock i think?? Does this matter what is a deadlock also??
sorry for the late repling is any one still interested how i wired up this system!??? I still have not managed to get the door card on properly! It is sitting about 3-5mm away from the actual door i could not get the clips to click back on!! Shall i take some pictures would be really nice if someone knew how to sort this out thanks in advance
right ok, i will post some pictures of the door card later this week or maybe the weekend and give an exact wiring diagram of this also. But basically the central locking switch on the drivers side i dismantled and bought another from ebay as the original one was used in the installation soldered some wires to the switch and plugged it back in. Its a pretty bodge job and i am not satified. So the lights dont flash and the horn doesnt sound and the boot release doesnt work. I am planning to do this over the summer when i have more time. thanks guys
CHEWY HERES THE PICTURES thanks mate
thanks mate
