car cutting out!
badboypolo
Post by badboypolo »
buy new gaskets? how much are they? and y?
inder
Post by inder »
only a couple quid or something, reason if you remove it totally, you need to ensure its all sitting down tight and sealed properly when you put it back, if the gasket is old and crummy or fails, then your going to have problems
its a cheap step, to renew them. think its only one for the throttle body - some metal one
badboypolo
ok thanks. :D think my car will be a bit more nippy when this is all cleaned up?
Iain_Mcl
Post by Iain_Mcl »
Previous owner had this problem on my car and she ended up paying nearly £800 get diagnostic checks and new throttle bodies. :shock:
badboypolo
its been fine latley, but I should still clean my throttle body, just not got round to doing it.
