central locking pump
scottybhoy
just wondering if any one can help me out hear the pumps now stoped working bit its makeing a hisss ing sound for about 20 - 30 seconds anyway that this can b fixed or if ill have to buy a new pump?
any help would b gr8
Scott.
Scott.
Christian6N
scottybhoy
not yet ill have a look 2 moro when ma mum brings the car bakinder wrote:If its hissing, it does not sound dead to me... could be a broken air pipe somewhere or just the main connection has come off the air pump - have you checked its on solid and not kinked or broken?
all was working gd when we got the car. went wrong from there tho
scottybhoy
ritey just had a wee look therescottybhoy wrote:not yet ill have a look 2 moro when ma mum brings the car bakinder wrote:If its hissing, it does not sound dead to me... could be a broken air pipe somewhere or just the main connection has come off the air pump - have you checked its on solid and not kinked or broken?
the bit where the air pipe conects 2 (the wee white bit thats screwed onto the metal) ther seams to b air comeing out of that not sure if its ment 2 tho any 1 know also any idea how 2 fix it
scottybhoy
inder wrote:no air should be leaking anywhere at all, sounds like that part has fractured or a pipe has come loose off it - the white bit is like a distrubutor for the air to all the pipes that go to door locks
can be easily replaced if this is the problem
just been haveing a wee think there would i b able to tape the pipe where teh airs comeing out with insulating tape until i get round 2 changeing the little white thing
scottybhoy
scottybhoy
scottybhoy
scottybhoy
bak again found out what was wrong pics bellow
the part circled is a kind of rubery type thing which has a hole in it so the air is leaking out tryed 2 tape it but no luck bellow is a closer pic of it
does any 1 know if i would b able just 2 get the rubbery bit or would i have 2 get the whole thing
also any 1 know how much it would b
