Installing ice
Discuss In Car Entertainment
scotia_polo
Installing ice
Post by scotia_polo »
Was just about to buy a sub woofer and amp until I asked the guy how much would it cost for them to fit it and he said 60 quid!! I live in Glasgow so is there anywhere or anyone that would be willing to fit it for cheaper!!Cheers guys
macemc86
Post by macemc86 »
if i lived close i would.
not hard at all though mate, you could prolly do it yourself with the help of a diy guide.......the hardest part i think is getting your power wire fromt he engine bay through the car.(and thats not even hard.can just be fiddly sometimes).
you'd save yourself sum cash doing it yourself...what model do you have, could see if i can take some piccies for you?
scotia_polo
thanks very much for the reply I appreciate it! I have got the mk4 polo 1.4cl the thing thats throwin me is my 6"9 and just the general wiring up, do I wire the sub to the amp then the amp to the battery, Am very confused!!
Alex_6n2
Post by Alex_6n2 »
yea the live wire is the only hard (more like annoying) part, esp if you use 4AWG or something as getting it through the bulkhead and then routing it out of site can take a while
everything else is just connecting, and positioning of your stuff
ModifiedMadness
Sponsor
Post by ModifiedMadness »
You run the power wire from the +ive connection on the battery through to the back (although you connect this last) that connects to the power terminal on the amp, the ground needs connecting to direct metal of the car's body, then the speaker wires are self explanatory. Hope that helped a bit.
scotia_polo
ModifiedMadness wrote:You run the power wire from the +ive connection on the battery through to the back (although you connect this last) that connects to the power terminal on the amp, the ground needs connecting to direct metal of the car's body, then the speaker wires are self explanatory. Hope that helped a bit.
Cheers guys for the help Am going to give it a shot il just take my time and take it at a step at the time. Cheers
ModifiedMadness
Sponsor
Just remember, connect the battery up after you know everything else has been done right to avoid any accidents and you'll be fine.
So in effect, last.
Alex_6n2
Post by Alex_6n2 »
and once it is connected be f00king careful! lol
if it touches the case of your amp etc etc it cud do some damage
plus it hurts if you get shocked as well, i know :lol:
ModifiedMadness
Sponsor
Best bet is to connect all the amp up first then connect the battery.
scotia_polo
good advice people it has defo been taken on board will be very careful when wiring the stuff up!
Del_GTi
Post by Del_GTi »
Routing the wires is the hardest part.
Take it you've got your RCA leads sorted aswell? These go from the back of the head-unit to the amp.
8)
scotia_polo
Del_GTi wrote:Routing the wires is the hardest part.
8)
hmm, I know my 6x9 run off the head unit would they be independent from the sub and amp, this is where it gets complicated :(
ModifiedMadness
Sponsor
Yeah, the RCA's carry the signal to your amp and through your sub, whereas the 6x9's will be directly from the H/U
Del_GTi
Post by Del_GTi »
ModifiedMadness wrote:Yeah, the RCA's carry the signal to your amp and through your sub, whereas the 6x9's will be directly from the H/U
What he said. :wink:
RCA's are like phono leads, 2 plugs a left and a right.
ModifiedMadness
Sponsor
You can't go wrong, black in black, red in red :D
