[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Heater Lights - UK-POLOS.NET - THE VW Polo Forum
I'm having the same trouble as the mint with the hole. The light turns on and off if I hit the side of the console. Kinda works like a switch. Hmm dodgy
Actually, some Polo's don't come with the heater lights. Mine didn't (1997 1.0 L) and so i fitted my own light. If you pop the panel off and look you should see two little hole where the bulbs would be but aren't. what model is your polo? L, CL etc.
I think some do and some don't have them as standard. Either that or the owner before me was in desperate need of a dash bulb!
To replace it... grab the center control (the one for the fan) and pull it out.. inside you will see the bulb.. get some plyers/tweazer type tool to pull it out.. i then got another bulb from halfords, pushed it in an wolah.. done..
