CAN SOMEONE HELP?!!!
i have a 92gt coupe, i can get it to idle from a cold start ive had this problem for some time now. the gt wont idle from a cold start its getting frustrating now cos i have to get up for work an extra 15 mins to give the engine time to warm up. otherwise the engine just cuts out when clutch is down. i have also noticed a lack throttle responce!!!! please help!!!
pay day soon. new mods sooon to come!!!!!
joe-Cardiff
idle troble
hardhitter
- Moderator
there is a mixture adjustment screw in throtle body thik its on the right hand side coming out at an angle take it out clean it with carb cleaner and refit count how many turns it takes to take it out and try an get it back in the same position it will now run sweet as a nut failing that temp sender blue one replace it
hardhitter
- Moderator
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
Mine did something similar to this.... as it was a very 'new' and worrying problem that developed on a single journey (suddenly, no 'go' up the hills etc) i gave the HT leads a little push extra (they werent loose), took off the inlets (no help), took the top off the air cleaner and gave the filter a shake out, and it was back to normal when everything was all together...
I refuse to believe "take out your air filter and shake it" is a viable course of repair though, so what was all that about?
lol, ive got the same problem. I took out the air filter and seemed to idle much much better. Ive still got the problem. Starts to shake the car a lot. Like its shivering. Its almost become a joke. Ive got some pictures of my engine. If someone could edit them and point to where im supposed to be looking it would b e a great help to everyone whos got this problem!
Thanks dan
http://www.markdot.com/modules.php?set_ ... _album.php
Thanks dan
