rear badge...
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
rear badge...
Post by loud »
how easy/difficult is it to change this for a black one? what is involved?
pagz
Post by pagz »
changing the front badge is pretty easy just got to remove the old one ... that housed and snap the black one in place...
BLACK6N_POLO
Post by BLACK6N_POLO »
pagz wrote:changing the front badge is pretty easy just got to remove the old one ... that housed and snap the black one in place...
the thread asks how to change the rear badge
inder
Post by inder »
its stuck on with double sided tape I believe, bit like the POLO text and engine size
Reeyad
Post by Reeyad »
Just removed mine was really simple, just grip it pulled of with some force, then take off any black sticky tape off, wash, clean and dry it well.
Make sure u line up the new badge before u stick it, give it some force then thats it job done......
polopowah
Location: Hertfordshire Drives: Ford Puma 1.7 Enjoys: Mowing grass
Post by polopowah »
this will always work.......
*park you car near where you have a power supply
*get mums old (or new :D) hair-dryer
*heat up the badge area (particularly around the rubber seal.
*get some fishing line or anything similiar thats strong, and gently saw away at the old tacky glue holding the badge on
*job done!
-Ben-
ModifiedMadness
Sponsor
Post by ModifiedMadness »
If it's the VW Double sided tape, that stuff is STRONG, I stuck the GTi lettering on my engine cover then wanted to move it a bit, it isn't going anywhere :lol:
loud
Post by loud »
so is there nothing underneath the badge? so boot could be completely debadged with no hassle?
inder
Post by inder »
loud wrote:so is there nothing underneath the badge? so boot could be completely debadged with no hassle?
nothing underneath, same paint colour as car :D BUT it will leave a slight circular indent... needs filling really
loud
Post by loud »
ahh ok. boo :(
JWC
Post by JWC »
You tried T-CUT? the chrome plating is only a few microns thick. Get some T-CUT and rub quite hard, you will find the plastic is black underneath. If not, you can always remove it as specified, but this way might work for you.
Reeyad
Post by Reeyad »
JWC wrote:You tried T-CUT? the chrome plating is only a few microns thick. Get some T-CUT and rub quite hard, you will find the plastic is black underneath. If not, you can always remove it as specified, but this way might work for you.
Good idea............ save some cash
But wont work for the front its actual a metal cover on top of the vw sign, was quite surprised, when I spotted that...
JWC
Post by JWC »
thought it was the back that you were doing?
polopowah
Post by polopowah »
LOL! this topic is going abit back to front at the moment :shock:
just to clear things up, the rear badge is all plastic and the front badge has a metal casing.
-Ben-
JWC
Post by JWC »
polopowah wrote:LOL! this topic is going abit back to front at the moment :shock:
-Ben-
Thus T-CUT is what is needed!
