martin9aj
Posts: 55 Joined: Tue Sep 28, 2004 5:45 pm
Post
by martin9aj » Mon Mar 06, 2006 8:55 pm
Hey
Can anyone tell me where the best place to put AXLE STANDS under the front end of a polo is?
The jacking points are marked but just wondering where best place to put axle stands are
PICs would be great
Sorry about such an obvious question!!!
Reeyad
Posts: 408 Joined: Tue Oct 15, 2002 7:42 pm
Post
by Reeyad » Mon Mar 06, 2006 9:07 pm
don't have pics, but I believe the correct place is just behind the front wheel, if u place your hand under the side skirt u will feel an indentation.
Thats where u should place the jack, am not 100% sure if this is the same place u can use the axel stands but I presume so.
polo boi
Posts: 724 Joined: Tue Feb 21, 2006 7:48 am
Post
by polo boi » Tue Mar 07, 2006 10:08 am
u can place the axel stands on the sills, polo's are light cars so it wudnt bend the sills in, but there shud b chassis legs 2 hold them on, im not sure tho
Giorgio
Posts: 350 Joined: Fri Aug 19, 2005 9:59 pm
Post
by Giorgio » Tue Mar 07, 2006 4:53 pm
polo boi wrote: u can place the axel stands on the sills
If you are talking about the strip of metal that runs behind/underneath the side skirts then your right. This is where we jack up most cars at work.
Once again I am not sure about where to put axel stands
phat6n16v
Posts: 107 Joined: Wed Jan 25, 2006 7:36 pm
Post
by phat6n16v » Tue Mar 07, 2006 6:20 pm
you put the axle stand in the same place you would jack the car up from and the sills for jacking and standing iver that or your could put an axle stand on the rear of the subframe.
Any 1 out there with a set of late VR6 calipers?
P20 DUB
Posts: 140 Joined: Thu Dec 15, 2005 11:02 pm
Post
by P20 DUB » Tue Mar 07, 2006 11:42 pm
put the axel stands on anything solid under the car.
theres pretty obvious places to put them wen u have a look.
good luck.
The_phat_controlleruk
Posts: 309 Joined: Sat Dec 03, 2005 10:40 pm
Post
by The_phat_controlleruk » Wed Mar 08, 2006 12:05 am
If you look on the sills, just under the doors, there are a set of downward facing triangles, one set behind the front wheels and one set in front of the rears, these are your jacking points.
P20 DUB
Post
by P20 DUB » Wed Mar 08, 2006 12:07 am
i think he knows that m8. he was looking for a place to put axel stands other than the sills.
P20 DUB
Post
by P20 DUB » Wed Mar 08, 2006 12:15 am
no appoligies needed m8. was just saying.
martin9aj
Post
by martin9aj » Thu Mar 09, 2006 6:30 pm
Yeah, It was a place for the axle stands that i was looking for,
but cheers anyway, All advice is appreciated
