hi there , havent been on for a while but had to drive the other halfs car the other day , and it dont have power steering
its mkiv 1.0L POLO on a T reg
and its like driving a bus compaired to golf
so is it possible to convert to have power steering and what would i need ??
anyone help
dunno, but i drive a 1.0 witout powersterrin and wot i have did 2 inhance the steerin is pumped up the tyre pressures to 35psi, recommend is about 28/30/32 dependin an its made a huge difference,
new steering rack £125
tie rods £42.50
tie rod ends £10 each
pump £85
bigger alternator £85 - 165 ( depends if you go for the 90 amp or the 120amp)
res and pipes unknown cost.
then theres the headache of getting it all in there. you have to fabricate a bracket for the pump as it connects to the drive belt ( alternator belt)
plum the whole system in and get her tracked its not worth the hassel imo but i think you can buy kits for abotu £200. /me wanders off to look for you.
so i supose part if they can be found on ebay and local breakers would come to about 150 ish plus loads a swearing fitting then lol
has anyone done it to their polo
Nosaj wrote:so i supose part if they can be found on ebay and local breakers would come to about 150 ish plus loads a swearing fitting then lol
i dont know anyone whoes done it but if you want to have a bash feel free but you will ned to fabricate mouning points for things. and teh steering racks may mount different.
and you will need a ramp as you will find its a b***h to remove the rack when its on stands. and there quite heavy so you have to watch youself.
Man...vw had a few lazy days and thought nah fuk it no power steering for this one... I remember when I was shoping aroung for my car I came across bucket loads without power steering... no central locking... wtf was they thinking ( as u can tell im still pissed of with a few of my wasted trips only to find no pas n cl )
[Moan/Over]
PAS, CL and passenger airbag were all options on the mk4 i have a 1999 S reg 1.4 L ( basic spec model) and it has power steering and pasengers airbag but had no leccy windows or CL. the model up from mine the CL model had the central locking but no pas airbag or leccy windows they were options awell.
thats not right mate, mine is a 96 cl model and has pas, airbag, c/l, e/w, e/, as standard.
if you look at my quote that you quoted i have hilighted a bit in bold saying that most were options but in the CL model central locking come as standard. so who ever baught your car from brand new payed extra to have these extras fitted. and i was saying the passengers airbag is optional the drivers was standard as far as i can gather.
if anyone has a mk4 brocour knocking around to prove or disprove my point it woudl be gladly appreciated but this is how i belive it to be.
the GLX model was the one wth electric everything AFIK
