Does anybody no if you can get into the rubber boot thing between the door and the sar by the hige? I have a break in my window wires and its gettin HOT!
Cheers guys
Big G
WIRES!
WIRES
Do you mean that you need to get to the wiring loom that runs from the door pillar to the door,if so its a major job i'd take the interior door trim of first to see if the broken wire is in there. there should also be a plug which you can disconnect so a door can be removed from its hinge's.IF the break is on the pillar side then thats a job for an auto electrician as they may have to remove the whole wiring loom that feeds the door. GOOD LUCK. NZ POM.
ok the wireing loom is integrated into the boot. so if you get a C spanner and unscrew the boot it will pop offthe car and unplug from teh car wireing. then take the doorcard off and you will see where that loom joins the other looms disconnect them plugs.
goto a VW dealer and say i need this be or failing that goto a scrappy. replace and jobs a goodun.
the door wireing is all modular so its easy.
