Picked up the car after work today. Running well and no main problems.
However looking thu the service recipts that came with it, at the 50k mile one says in the advice section...
1. Cam belt needs replacing as has cracks in it - no problem as I plan this anyhow.
2. Rear shock absorber leaking (leaking what??) and recomend replacement pair - has anyone one else had this and done it - whats the cost?
3. Throttle housing contaminated with oil - requires cleaning- can I just blast it myself with carb cleaner or will this goose the temp sensor? I dont want to make it worse. Can I do this with the engine of and a cloth rather than while its being reved?
4. Distributor cap & rotor arm burnt/worn - whats this all about and is it nothing to worry about?
All this is fron a VW main dealer @ 50,000 miles.
ta
Picked up the car - few issues tho.
mister_burns
loud
- Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
cleaning the top of the throttle body is fine, i blasted carb cleaner into it to clean the guts too and had no problems, but some people have knackered their temp senders doing this.
if you reach round the back you find the cable that activates the butterfly valve so you can open and close it and spray at the same time
olop_chris
- Sponsor
mister_burns
olop_chris
- Sponsor
olop_chris
- Sponsor
