Mine worse than yours! It runs from the battery. Along the back of the engine and thru a grommet coming into the car just above the pedals. one of these things I've been meaning to sort for 2 years now. The fuse hangs near the powersteering gubbins . I do check the cable for damage regularly mind you
I set fire to the Lupo when it was about a year old through a power cable.
The car spent 3 months at VW under investigation to find the fault, to then have the wiring loom replaced under warrenty.
yeh its abit dodge. I'll sort it at the weekend I think. I dont want my Polo catching fire. That would be sad
Theres probably away of getting the cable into the area where the windscreen wipers are. Not sure about the fuse location, its suppost to be a maximum of 18inches from the battery if i remember rightly. I'll have a look and see what i can see.
