i take it the rear wheel bearing is built into the rear drum housing on my mk3 1.3 cl? when i had it apart other day (handbrake cable snap) i noticed a second smaller bearing that also slots into the drum once its on the car and is then held by a nut and split pin/cap assembly. which parts do i need to change? and how much?
whats the easiest way n all, take drum off and take it away to get the bearing pressed in?
any advice more than welcome!
cheers
Coops
Rear Bearings
buster.g40
Rear wheel bearings
SKF part number for rear wheel bearings is VKBA529
