where can i get a rear wiper blanking plate
want to de clutter the boot and want to start with the badges and wiper.i take it the whole wiper motor has to come out.any ideas on what to use to blank the water supply tube off with and where can i buy yhe blanking plates from once the wipers removed.anyone with a link on number where i can get them would be great
willriseley
removed the wiper and bent the water supply over and cable tied it.i got a rubber bung for the standard plate and think im going to have to use some clear mastick to fix the plate back in position until i can get a proper blanking plate.any other ideas on how to fix the original bunged plate back in position other than mastick.also even with the proper blanking plates,are they safe as i noticed the boot lock mechanism could possibly be tampered with if the plate is removed,due to the hole being left due to the wiper being removed.has anyone had problem with people popping the boot lock using the hole left after removing the wiper
willriseley
went to focus today to add some security since removing the wiper.i brought a smooth headed black m10 bolt and black rubber tap washer and put a metal washer,front and back before tightening up.i then plugged the black plate and used heavy duty velcro cut to size to cover the bolt till i get a proper blanking plate,job done and no one can pop the boot.sorted!
willriseley
