Well I have been doing some research, and I'm gonna fit rear speakers to my 1.0E - but they are gonna be VW speakers and gonna have VW grilles and gonna be in the doors!. Now your probably sitting there thinking how is he gonna do that, especially with a BETA head unit.
So first step, I'm getting hold of a GAMMA head unit. Then getting the radio code, fitting it etcetc. Next step - wiring. Gonna try and get a proper loom if not get one made up for the rear speakers.
The next thing will be to get hold of the brackets for the inside of the door for the VW speakers. I know there are holes for the bracket - and I know where to get the bracket
Then I have to get two old front door cards off a polo, and remove the bottom grilles from them (or get some 5 door GTI doorcards). Drill the holes out in the door in line with the speaker bracket, and mount the grille (same as the front in effect). I'm also gonna fit the tweeters same as the front in the tops of the doors. After that, gotta mount the speakers, connect all the wires and fingers crossed it will all work.
I know I sound like I am mad with this crazy idea, but I'm gonna make it work - and I wont stop till I've done it. Im gonna photoshop it a bit later when I have a chance.
All left to do then is the foglights and the new grilles and im finished (ill most likely find something else i want to change though
Cheers Guys,
Alex
