Hey, Yes they will fit, If you have these tyres, they will JUST fit around your wheel arches... I know this because I have the same 16inch alloys and same spec tyres...
The front wheels will go full lock both directions no problem, but literally leaving 10mm (if that) between tyres. The rear wheels are can be a problem, the plastic wheel arch can be modified yourself by makin the wheel arch bigger using allen key to adjust.... I found that on my Left rear wheels have plenty of space.. but the right hand, it was really tight and was scrapin when on roundabouts :S... but i think i fixed that prob now
But yeh, they will fit, but as carmadaaron, recommend gettin lower profiles...
