Main Beam Bulb
Main Beam Bulb
I bought some Phillips blue vision bulbs. A pair of H1's and some W5W's. Now the W5W's are the sidelights and i thought the H1 bulbs were to replace the ones that you use for main beam. But the guy at the garage said they were the same as the Xenon bulbs
Confused
ModifiedMadness
- Sponsor
Philips blue vision are xenon filled bulbs with a blue tint, that makes them look like Xenon HID - thats why he said it. The H7 is the dipped beams, but in the GTI, they are Xenon HID as standard
Xenon bulbs are available in H1, H4 and H7. Ive got dipped and main beam in mine with xenon bulbs, and the difference is amazing!
Cheers,
Alex
Cheers,
Alex
Well, in mine it was easy - im not sure as for the GTI due to less space in the engine, but I shouldn't think its much different.
You take off the black plastic case on the back of the headlight, then just unclip the bulb (its the one above the sidelights
) Theres like a metal wire clip that holds the bulbs in place - you can see it if you look into the headlamp unit on the back. Just unclip that, and put the new one in.
Remember though NOT to touch the bulb glass on the new bulbs - it can limit their life by up to 70%!
Also, if you havent fitted them already, the old sidelight bulbs just pull out - a little force might be needed but they will come out
Best to pull on the black holder for the bulbs
Cheers,
Alex
Cheers,
Alex
Heh heh heh, sometimes I wish I was a non GTi owner, ignorance is bliss.You take off the black plastic case on the back of the headlight
I was initially puzzled when I tried changing my sidelight bulb on my Gti.
The GTi's need to have the front bumper removed to change the bulbs. There's a step by step in the DIY section.
I have a sidelight out and an MOT in April, so my bumber will be coming off at somepoint soon for a bulb change.
