Specification
Engine
Cylinders: four in-line
Fuel supply: sequential fuel injection
Cubic Capacity: 1984 cm3
Valve gear Soupapes: dohc, four valves per cylinder
Ignition: electronic, Bosch MS3.1, with 128MB data logging
Fuel requirement
Engine Output
Max Power ISO (kW): 210 Kw (282 Hp)
Power peak: (r/min) 8250
Max usable: (r/min) 8500
Torque Peak: (r/min) 7000
Transmission
Forward speeds: 6
Driven wheels: 4x4
Front differential: Mechanical Limited Slip
Rear differential: Mechanical Limited Slip
Centre differential: Mechanical Limited Slip
Clutch/Ambrayage: AP Racing twin plate
Wheels and Tyres
Gravel Rally wheels: 6.5Jx15 alloy
Tarmac Rally wheels: 8J x 18 alloy
Tyre size gravel: 195/65 R 15
Tyre size Tarmac: 235/40 R 18
Brakes
Front calipers: 300mm ventilated discs with 4-piston Alcon
Rear calipers: 300mm ventilated discs with 4-piston Alcon
Hydraulics: dual circuit with balance bar
Steering
Type: Rack and pinion, power assisted
Lock to Lock: 2 turns
Suspension
Front: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
Rear: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
Capacities
Fuel tank: 70 litres
Dimensions
Overall length 3916mm
Overall width 1800mm
Ground clearance 170mm
Wheelbase 2470mm
Track front 1587mm
Track rear 1587mm
Weight
FIA (minimum 1150kg) 1150kg
More vids:
https://www.youtube*.com/watch?v=uYxoSAnT-mU
https://www.youtube*.com/watch?v=8BpkP_yjA10
https://www.youtube*.com/watch?v=bPhjtJQzPrA
https://www.youtube*.com/watch?v=MzvjEAoQwtc
