Small rust problem.
Detailing & Bodywork
farmio
Small rust problem.
Post by farmio »
hello,
I think that i asked this in the wrong part of the forum.
Whats the best way of dealing with bubbling rust/paint. the rust is only slightly cmoing through, about the size of a 5 pence piece.
I dont really want to go made by grinding it off because i cant afford a professional resray at the moment cos of starting a new job. Was going to get a can mixed up by VW and have a go but what do you guys suggest.
Ill try and get a photo tonght.
polo244
Post by polo244 »
the only way to get rid of it is to rub it down to bear metal then smooth it with filler if you need to
farmio
Post by farmio »
that would mean spraying it. how good a job could i get from a can from VW?
Its right in the middle of the pannel so its a pain.
Someone else has said to try red oxide? anyone have a clue what thats about?
dragon_green
Post by dragon_green »
red oxide is a type of primer.
is your car a solid colour or is it metallic? i'll tell you this - you won't get a metallic spray to look like the original paint.
Chally_Rai
Sponsor
Post by Chally_Rai »
dragon_green wrote:red oxide is a type of primer.
That, is very true! The previous owner made a rough repair on the side of my bonnet, the paint doesnt match and i rekon thats why.
I have a rust problem now on my boot too, so I literally scrape the stuff off? :( its like 4 ot 5 round bits les than a centimeter in diameter but i wana get rid of it now rather than later
