under car neon lights
is it possiable to fit under car neon lights without having a body kit, or side skirts.
tornado_ally
Hey Jazz. Nice to see you on the forum. A garage along my road does under car neons. He is one of those old fashioned mechanics and gets his job done. if i come down Southgate then i wil drop by yours and i can give you his address and telephone number or we can go together. Worse come to worse you can take your car to Clifford on Essex road. My mate will put them on for you for free but remember they are illigal
Nelson_Wilbury
- Moderator
Erm...KarlM wrote:
btw Nelson, my neons are in 'Festive Mode' at the moment - flashing all 7 colours! Booya!
@ Jazz. I don't wish to offend you, but these are the sort of cars that deserve neons...
My advice is keep the £30 its gonna cost you for the 'neonz' and get either
a) Cubby box mod
b) High gloss door trims
c) Aero wiper (if you haven't got it already)
Just my 2p
KarlM
you'll get the transformer in the kit as, i would suggest spending extra and getting some like mine, instead of neons they are LED bars that can be set (if your that way inclined) to flash in different patterns, even in time with the music. these are waterproof and will last loads longer than neons.
If you know anything about electrics you should be able to follow the wiring diagram, if not and ICE dealership will charge between £50 and £80 to fit them
neons or led
Thanx nelson. I used to share ur opinion about the novas and the neons, but I have recently seen a few 9n polos wiv neons and they do look gd.
Where can I get the leds from KarlM and how much r they.
KarlM
Benefits of LEDS
1) Tough and Durable - the LED Tubes contain no glass and can flex with the vehicle's chassis.
2) Flat - no big round neon tubes hanging under your car.
3) LED Ground Lighting is brighter than any Neon Ground Lighting - even Streetglow.
4) They are unaffected by temperature and reach thier optimum light output immediately.
5) 100,000 hour Lifetime - Neons are 15,000 hours if they don't break on a bump in the road or a "sleeping policeman" (speed control bump).
6) Safer - there is no glass to break - LEDs are made of resin and they are encased in a Polycarbonate tube for additional protection.
7) Low Voltage - they operate directly from 12 volts unlike all neons which require a voltage of at least 1,000 volts from an inline transformer.
Easy to fit - no transformers to worry about
9) Longer - most neons sold in the UK have a maximum length of just 39 inches.
10) 12 Months Warranty - against defects in workmanship.
Click which ever pic you need. prices are on the site.
UK Law: If the tubes themselves are visible then specific colours have to be used i.e red for the back, orange for the sides, white for the front etc.
There is no definitive law for lights placed underneath the vehicle, they are not classed as legal or illegal. Technically the light is not projected, it is only a glow - so the colour shouldn't matter. However the legal situation for lighting under vehicles is not clear cut and cannot be satisfactorily answered until there is a law made defining their legality. We are pressing for clearer up to date laws on the matter and would like to get them legalised.
Check out the current U.K law: http://www.legislation.hmso.gov.uk/si/s ... preflector
It is important to mention that a minority of the Police don't like ground lighting and may ask you to switch the system off. If they are met with verbal abuse or arguing then they could find a reason to issue a ticket.
At the end of the day it is up to your own discretion as to whether you switch your ground lighting on whilst on the road.
neons
Hey m8,
Yeah it's not too hard at all to fit them yourself. Basically follow all of the instructions and use a haynes manual to help u out if u can't work out the electrics. I had them on mine until some thieving bastardo nicked them off so make sure they can't see them. Sadly all of mine were out of view except the back one (hardest to hide without a diffuser). If I get some more i'll either get a diffuser or wire them up without a rear tube.
If I can get the time I will post info on how to do it with pics on the mods page.
