Front door speakers
Front door speakers
im looking to upgrade my front speakers in the polo as they pop when its not even that loud now, but i want to keep my standard system as i have a single cd and a cd changer!
first question what size speakers do i need for the front doors to fit were the old ones will come from!?
second question can anybody recomend any decent speakers at a reasonable price
anybody got pics of upgraded speakers in the polo?
mine are 16.5cm - they are a nice fit. I upgraded mine to Encounter speakers, which have a 250W peak, but I have them running off an amp so they are much more powerful.
It will be difficult to use uprated speakers on the gamma, as its max output is 4x20w. To run a 250w speaker will put quite a bit of strain on it
Personally, I would have it amped. The GAMMA HU has preouts on it - you need an adaptor from www.bluespot.co.uk to get the leads for it to work
ModifiedMadness
- Sponsor
The peak may be 250w Alex, but I bet if you gave it a full 250w it would last a few seconds before smoking and then failingalexperkins wrote:mine are 16.5cm - they are a nice fit. I upgraded mine to Encounter speakers, which have a 250W peak, but I have them running off an amp so they are much more powerful.
The ONLY figure to pay any attention to is the RMS figure.
Exactly as I said peak. I think mine are about 150W each on the RMS and ive got a 300W amp running themModifiedMadness wrote:
The peak may be 250w Alex, but I bet if you gave it a full 250w it would last a few seconds before smoking and then failing![]()
BETA headunits dont have a preout unfortunately. The reason they pop is usually due to the headunit - factory fit speakers are fairly durable. The popping is because the signal gets so distorted where its amplified, all you get is nasty sounds
ModifiedMadness
- Sponsor
