Polo 6N2 Splitter Removeal
As Above, Can anyone shed any light as into how to remove that standard splitter of a 6N2 ?
unscrew the lower screw on each side of the front wheel arch. jack up front of car, get under it with a screwdriver and you will see a lot of clips holding the splitter on. get a flat head screw driver and push the clips out with the screwdriver.
Start from one side and work your way around. Its a b***h of a job because i did mine the other day.
hope this helps.
hope this helps.
If your worried about damaging the paint with the screwdriver, then just open the 2 torx screws on either side, and give it a good tug.
Once you get it moving, the rest will come off pretty easy
Putting it on is the same way, start from one side, and work your way across. Might need to make sure its sitting flush all round, before you can clip the last corner in. You'll see what i mean when you do it
- bstardchild
- Moderator
I just recently changed my splitter from the original to the GTi, and i fought i was a big head ache, but once u know what ur doing it can be straight forward.
Firstly if i was u take the bumper off, its will give you better work space, use the hayes manual as a guide.
there is screws on the original splitter and the are clips which hold it in place, unslot the clips and it will slip off.
