Alarm help *hazard light*
s-l-i-x
Post by s-l-i-x »
Hi, I've fitted an alarm on my polo and its works fine apart from we dont know where the hazard light output is on the car?.....
Does anyone here know? Cheers :lol:
PD
Post by PD »
When i fitted my Remote locking kit it had two wires for the flashers, one goes off to the left side lights and the other goes to the right indicatiors. you should be able to find those cables in the loom in the front i connected mine directly onto the wires in the boot going into the rear lights.
dont know if this helps.
you best bet is getting a haynes manual and looking at the wiring diagrams.
s-l-i-x
Post by s-l-i-x »
Ok might just run a cable to the rear lights, thanks for that
PD
Post by PD »
s-l-i-x wrote:Ok might just run a cable to the rear lights, thanks for that
well the loom runs to the front of the car, not quite sure where you can find the cables.
I think you can possibly connect the cables onto the hazard light switch.
alexperkins
Site Admin
Post by alexperkins »
Indicator wires are Black/White and Black/Green in the big loom under the dash! :D
s-l-i-x
Post by s-l-i-x »
Ok thanks PD & Alex :D
