gear box problem (diagnosis now in)
was driving the car today and all of a sudden it started making funny noises like a loud whinning it feels like the gear box, the noise isnt there when you put your foot down but when you lift off it makes and aweful whinning noise like something is turning round and scraping on something else!
as i said it feels like its the gearbox as i cant feel it through the gear stick and not the steering wheel
could any body shed some light on this for me im really stuck here!!
drove it again tonight and the gears seem to clunk in when you change could this be the clutch???
Nah, gear box mate....i got the same whyning and eventually the gears stared playing up.....Dont drive it!!!! Because it'll be bearing and you'll eventually star knocking teeth off, losing gears and ultimately blowind a hole in the diff
Thats what happened to me! It wasnt a long process either.....matter of a couple o days!
what did you do about it???Dee-vub wrote:Nah, gear box mate....i got the same whyning and eventually the gears stared playing up.....Dont drive it!!!! Because it'll be bearing and you'll eventually star knocking teeth off, losing gears and ultimately blowind a hole in the diffThats what happened to me! It wasnt a long process either.....matter of a couple o days!
and what was the actual problem diagnosed as??
That would be ideal. My mate is a mechanic so he would maybe do mine in spare time.vdubit wrote:How mechanically minded are you? Rebuilding the box is quite easy really. I have a list of all part numbers required, costs around £130 for the lot.
I have a GTI, so i might rebuild a spare GTI box then swap them over.
VW part numbers to the left, timkin in brackets. I found they were cheaper from the dealer than a bearing supplier. Ideally the plastic bearing could be taken to a bearing specialist and matched to a metal one, this may rectify one of the problems.
085 311 123 D x3 (timkin XC06536CD-JXC06536DC) 2xLayshaft, 1xMain Shaft - £14.30ea
311 405 625 F x1 (timkin XC10240CJ-XC10240DH) Mainshaft - £10.40ea
411 501 283 G x2 (no timkin numbers taken, sorry!) Diff Bearings- £14.30ea
085 311 431 C x1 (Crappy plastic bearing) 5th Gear Idler Bearing - £4.85
085 311 113 x1 Seal - £5.20
084 409 189 C x1 Diff Seal - £9.45
084 409 189 B x1 Diff Seal - £9.45
085 301 215 A x1 End Plate Gasket - £6.69
085 311 582 x1 Crappy Clip Thats Bound to Break, holds in selectors.
