what are the advantages of the gamma headunit over the beta version??
is it worth upgrading??
Gamma HU - Advantages over Beta???
Gamma kicks out the same output, but instead of 2 x 20W its 4x20w so can run rear speakers also. It also has preouts so you can run a sub or amped speakers, and also remote voltage to turn an amp on.
Ollie is also right in what it says about dolby noise reduction, and a fader. You also have TIM so it will record traffic info broadcasts, and soft touch fast forward and rewind on the cassette. It can also play both sides of the cassette without the need to flip it over.
You miss posted, and I put the reply in tha thread
No you cant use the CD Changer unforunately - VW gear is only compatible with VW HUs
Blaupunkt are very good - i have one in mine sound quality is fantastic
And yes you do, though there are adapters so you dont have to cut the ends off (the wiring isnt that great to be honest!!)
- h4r1s
- Platinum Member
- Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
i've been told that my cd changer isn't oem, but it works perfectly with my gamma hualexperkins wrote:You miss posted, and I put the reply in tha thread
