Gamma HU - Advantages over Beta???
stani540
Post by stani540 »
what are the advantages of the gamma headunit over the beta version??
is it worth upgrading??
Ollie_R
Sponsor
Post by Ollie_R »
IIRC, the Gamma has a fader and Dolby noise reduction over the Beta. The fader may be beneficial if you have a subwoofer in your car; well that's what the guy who did my audio said.
stani540
Post by stani540 »
i just want to upgrade my speakers in the front doors and wondered whtehr id get better results with a gamma
Gamma kicks out the same output, but instead of 2 x 20W its 4x20w so can run rear speakers also. It also has preouts so you can run a sub or amped speakers, and also remote voltage to turn an amp on.
Ollie is also right in what it says about dolby noise reduction, and a fader. You also have TIM so it will record traffic info broadcasts, and soft touch fast forward and rewind on the cassette. It can also play both sides of the cassette without the need to flip it over.
stani540
Post by stani540 »
im starting to think id be better off with an aftermarket HU but are there any i could use my cd changer with??? im looking at a blaupunkt one atm
also how do i fit speakers in the front door do i just chop the wires and the vw plug off then wire the aftermarket ones in??
You miss posted, and I put the reply in tha thread :P
No you cant use the CD Changer unforunately - VW gear is only compatible with VW HUs
Blaupunkt are very good - i have one in mine sound quality is fantastic
And yes you do, though there are adapters so you dont have to cut the ends off (the wiring isnt that great to be honest!!)
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
alexperkins wrote:You miss posted, and I put the reply in tha thread :P
i've been told that my cd changer isn't oem, but it works perfectly with my gamma hu :roll:
stani540
Post by stani540 »
mines a panasonic dunno if that makes any difference????
It may well work with a blaupunkt HU, as the BETA GAMMA DELTA and RCD200etc are all made by blaupunkt...they just have a VW fascia to them!
stani540
Post by stani540 »
right well i think im going to go for the Blaupunkt Kingston MP47
and im going to put in some new speakers but was wondering if i only have a beta HU that is only 2x20W do i have wiring for speakers in the back already there or do i need to put it in????
Nope no wiring in the back...you would have to add it yourself. The radio you have chosen has a 4x50W i seem to remember at least its something close to that - you would have to add the wiring either through the ISO connector, or through a preout with amped rear speakers
