Amp question
Discuss In Car Entertainment
brew1988
Amp question
Post by brew1988 »
I have two 10" 400w subs and 2 6x9's, if i want an amp to run them both how many channel etc does it need to be as i have no clue.
Hardcore
Post by Hardcore »
if i was you. buy 1 amp. or even 2 amps. if you connect your 6x9's up to your head untit it should power it sufficiently. and you need an amp to power your subbs. preferably a 800watts one, with 2 outputss. which splitts it to 400 watts each.
if you want to have it proper good. i would buy another amp. which is 200 watts. and applies 2 channels. with 100 watts each. to power your 6x9's aswell as the other amp for the subbs.
dont buy a huge amp with loads of outputss cus youll either blow your 6x9's or wont power your subs to full potentiel and it will sound well horrible. also make sure you buy the right amp for the job. sum amps are designd for 6x9's. which you can identify by the class. you need a class A-B amp for 6x9's i think.
brew1988
Post by brew1988 »
big help dude cheers
Bepe
Post by Bepe »
dont connect your 6x9's to your head unit, it will sound gash
