adjusting headlights?
well basically, you use vag com to put them into learning mode. From that point you set the level they should be at normally and then learning mode finishes. From that point on, the new level is the reference point, and teh car adjusts the headlights up and down as per its orientation if that makes sense
- Tim_GTi
- Post Whore
i see, but (without sounding dumb here), what is vag com?alexperkins wrote:well basically, you use vag com to put them into learning mode. From that point you set the level they should be at normally and then learning mode finishes. From that point on, the new level is the reference point, and teh car adjusts the headlights up and down as per its orientation if that makes sense
bristolgeezer
- Tim_GTi
- Post Whore
alexperkins wrote:VAG COM is a program used to diagnose and clear faults/change settings in the ECU. VW use it as do audi, seat, skoda etcetc
Its an incredibly powerful program, and can really mess your car up if you dont take care with it lol
ahhh right ok, i totaly get it now, but how do i access vag com? to adjust settings like the setting below.........
??alexperkins wrote:[Select]
[55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
I think what you're wondering is what do you use to use VAG-COM - You'll need a tool from a company such as Ross-Tech which then plugs into the Interface in the Ashtray (Next to the Cigarette Lighter the tray pulls out and underneath is the interface). Check out Ross-Tech.com for some info. I'm sure Alex will let you know where to buy one.
ModifiedMadness
- Sponsor
ModifiedMadness
- Sponsor
