adjusting headlights?
alexperkins
Site Admin
Post by alexperkins »
Ill be interested to see if the headlights keep that position - they often reset!
Tim_GTi
Post Whore
Post by Tim_GTi »
alexperkins wrote:Ill be interested to see if the headlights keep that position - they often reset!
yeh, i didn't quite get that bit about how to get them not to reset when reading that guide?
alexperkins
Site Admin
well basically, you use vag com to put them into learning mode. From that point you set the level they should be at normally and then learning mode finishes. From that point on, the new level is the reference point, and teh car adjusts the headlights up and down as per its orientation if that makes sense
Tim_GTi
Post Whore
Post by Tim_GTi »
alexperkins wrote:well basically, you use vag com to put them into learning mode. From that point you set the level they should be at normally and then learning mode finishes. From that point on, the new level is the reference point, and teh car adjusts the headlights up and down as per its orientation if that makes sense
i see, but (without sounding dumb here), what is vag com?
alexperkins
Site Admin
VAG COM is a program used to diagnose and clear faults/change settings in the ECU. VW use it as do audi, seat, skoda etcetc
Its an incredibly powerful program, and can really mess your car up if you dont take care with it lol
bristolgeezer
Post by bristolgeezer »
yeah i got a gti,
i just turned the adjuster screws the old fashioned way of adjusting your headlamps and they seem fine so far, tbh i've never noticed them adjust themselves before,
cheers,
ash.
alexperkins
Site Admin
They adjust as per weight in the car and gradient - clever really. youd never notice it as its so slight lol
Tim_GTi
Post Whore
Post by Tim_GTi »
alexperkins wrote:VAG COM is a program used to diagnose and clear faults/change settings in the ECU. VW use it as do audi, seat, skoda etcetc
ahhh right ok, i totaly get it now, but how do i access vag com? to adjust settings like the setting below.........
alexperkins wrote:[Select]
[55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
alexperkins
Site Admin
You go into the module for electrical, then lighting, and in the box type 55 and hit enter. It then loads up the config for that controller. Just have a play there isnt much you can do in electrics anyhow :)
womble68
Post by womble68 »
I think what you're wondering is what do you use to use VAG-COM - You'll need a tool from a company such as Ross-Tech which then plugs into the Interface in the Ashtray (Next to the Cigarette Lighter the tray pulls out and underneath is the interface). Check out Ross-Tech.com for some info. I'm sure Alex will let you know where to buy one.
alexperkins
Site Admin
EBay they are like a fiver. Just search for VAG COM CAN BUS cable :)
To be honest, it would be easier to just go to a dealer lol let them do the hard work!
ModifiedMadness
Sponsor
Post by ModifiedMadness »
Seconded, at least if they do it wrong you just have to go back and make them sort it. They don't always charge people.
For example, I paid nothing but Si_GTi was charged. Seems like they make it up as they go along.
alexperkins
Site Admin
I think it depends on which person you talk to - go direct to a mechanic round the back and your more likely to get it free than to go through service
ModifiedMadness
Sponsor
I went through Service, but then the bird is always really flirty when I go to her (good looking too which is why I go to her) :lol:
alexperkins
Site Admin
haha love it :D
