I think I know the problem with the door handle, as it's happened before. When I pull on the driver's side handle, it just pulls all the way out until it stops, and doesn't trigger the latch. The last time it happened I watched as it was repaired and it seemed like there was a thin, metal prong which snapped at the top where it should press against the handle internals as it opened. Is it common, and is it feasible that I could repair it?
Also, my central locking has decided to play silly buggers. Unlocking is fine, but when locking the motor (I assume, pump maybe) which I can hear near petrol cap stays on. From reading about it seems that it could be a problem with the pump, and someone else has suggested to me that it may be the solenoid for the petrol cap lock, as they can get worn(?). Again, any ideas or fixes would be greatly appreciated
