Engine Start Push Button
randy
Post by randy »
Has anyone fitted an engine start button into their polo and how easy is this?
Anyone able to talk me through it?
alexperkins
Site Admin
Post by alexperkins »
It just needs to be a link between the power on the starter motor - you will still need the key in to create ignition, and to disable the immobiliser. Unless you choose to install a keyless go system similar to mercedes.
carerra91
Post by carerra91 »
alexperkins wrote:It just needs to be a link between the power on the starter motor - you will still need the key in to create ignition, and to disable the immobiliser. Unless you choose to install a keyless go system similar to mercedes.
i wish i worked at vw :D
alexperkins
Site Admin
no you dont lol trust me!
BIG4244
Post by BIG4244 »
id never wish for anyone to work at VW!! i installed a push start on my previous car (vauxhall nova, i know its bad!!) i used a big red button from maplins for about £2 and just swapped the starter live on the back of the ignition barrel so it went to the switch, you still had to have the key, but just to put the ignition on, pretty sure you can do the same on the polo
Tim_GTi
Post Whore
Post by Tim_GTi »
my mate had one of these installed in his Zetec S, i dont really get them though, whats the point in a push button start if you have to put the key in in the first place?
BIG4244
Post by BIG4244 »
its just cool!!
Tim_GTi
Post Whore
Post by Tim_GTi »
BIG4244 wrote:its just cool!!
ahhh well if you'd said that in the first place.....!!! 8)
