[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Door handles - UK-POLOS.NET - THE VW Polo Forum
As you know, mk3's have a plastic strip in the middle of the handle. i want to take them out and spray them. they seem like i can pull them off but im not sure.
if i remember rightly, the got 3 clips in total, one at one end, one at the other and one in the middle! carefully prise em off n u should see the clips, if ya careful, u could use a flat blade screw driver!
Use a tiny straight-headed driver and pop the clips out. Make sure one side of the clips are out before you start yanking at it, or it can quite easily snap
had them in my MK2, wasnt fussed on them they didnt go with any thing on my car?!! replaced them with carbon inserts now, they are also on old jetta's, audi's and golfs, all MK2.
not sure about colour coding the strip?? mite be better off colour coding the whole handle??? jus an idea?
