Bought a Lemon! need help please
frankeygsxr1000
cheers to everyone for there quick replys they've really helped me big thank you to TIM gti ,tegwin, mouse, 8080
I guess from what ive read already in this forum its gonna be a labour of love but im gonna get it all sorted as im totally in love with the motor the best car i've owned and i've had a few
I think im gonna get my mechanic to sort the sensor and try resetting the scan i let you know as i find out its going in tuesday for the rest of the work ie-
-both steerin rack arms
-n/s/r wheel bearing
-all new brake pads
-middle exhaust hanger bracket
-new oil breather hose
-new rear wheel speed sensor(hopefully this will sort the abs problem of the pump been out of tolerance)
once again thanks to all who helped a newbie to this forum i'l post soon as i know more
oh and ps gonna mod the grill with a nice red trim as it looks minted after reading so quality D.I.Y tips
Cheers all please post if anyone has anyother ideas
Thanks Lee
-all new brake pads
Thanks Lee
My god mouse, wtf? £100 for air con recharge??? Jesus, i charge £35! Mot i charge £25. Rear discs and pads cost me less than £20 all in, Cam belt kit was £50. £100 for a headlamp bulb? Got my 6000k pair for £40. Not only that, but the part numbers are gsf numbers, so you can work out how much profit they made on it all!
frankeygsxr1000
frankeygsxr1000
frankeygsxr1000
Ok so my mechanic rang me to tell me all the works been done thats needed to the car ie
Cam belt/tensioners/guides replaced.
gearbox seals replaced.
lamba sensor replaced.
new brake pads all round.
oil breather hose replaced.
n/s/r wheel bearing replaced.
n/s/r wheel speed sensor replaced.
both steering rack arms replaced.
Rear hi level brake light fixed.
So all errors have gone now expected 1
abs pump outside tolerance
But my mechanic has had a good look at it all and gave me 12 months MOT
as long as i sort the abs pump soon as poss
So looking about am i best of just sending mine off for a refurb cause i rang round loads of breakers and no joy anybody got any ideas bar going to the local stealers ie £657 off them
Thanks lee
Thanks lee
frankeygsxr1000
My ABS light is on nearly everyday and that is apparently because of the ABS pump.
The chap in my local garage said it isnt the pump though, and that the rings which the ABS speed sensors "read" could be dirty/corroded/cracked and that i should have a look at cleaning them up before spending £600 for a new pump to still have the problem.
Just thought i'd let you know you're not the only one thats bought a lemon mate
A week after i bought mine i wasn't happy with the clutch. Got it checked and the numpty that had it before put a recon clutch in
So new clutch and front discs and pads done a week after owning it.
Had the car about 6-8 weeks now and just looked at my tyres today and i need 3 of the blighters
Spare keys batteries need changing so will probably need to reset that too.
I'm dreading on when it needs mot and service later this year!!
But tbh, i still love it
Colour-concept
Try changing the sensor first buddy alot cheaper.
Had my ABS light on in the Colour concept, took sensor out blew it off and put it back in and hey presto cheap solution to my problem.
Moral of the story.... try the cheap thing first...
1200 odd quid for a service and MOT..... that has shockd me.....
frankeygsxr1000
Cheers for all the great replys's least its gone through the mot today
With a bit of a bad bill but its okay for 12 now so gonna spend some time this weekend on her all been well and dependant on the weather....gonna get ever wheel sensor we'll 3 of them as i've had 1 replaced just generallly clean the rest of them...
is there a post about where the sensor are located or has any1 got any good advice on them sorry but never worked on such a new type car my old beamer was 1995 so pretty easy compared
Thanks Lee
Thanks Lee
