My 1st Polo
Avinitlarge
My 1st Polo
Hi
Just bought a P reg Polo, 1.4 16V. Its Possible the worse thing Ive ever done to be honest.
Good points
it has 4 doors
Bad Points
Rust across the top of the windscreen
Think the windscreen is letting water in
Drivers side electic window doesnt work
Loads of travel in the brake pedal
Blowing water out of the expansion tank
Heater doesnt blow warm, Never mind hot
Any suggestions??
I know Andy "puddin" Coggan, The owner of motors in motion, Parts are not a problem,But Its it actually worth repairing??
After looking at the common faults, Its makes me glad Ive got my Pajero, It wont go wrong
Good points
it has 4 doors
Bad Points
Any suggestions??
Its probably that the:
The Electric window is just a common fault and you could probably go to a scrappers and pick up the new mechanism for £35-40
As for the Rust just take to body shop and get them to sort it
And ur Brakes i dunno, is it leaking brake fluid, brake pipes corroded? I dunno im no expert just assuming hehe
Hope you get ur polo sorted m8 it is a fun car to drive when its working properly =D
Are all related. Ur Heater Matrix sounds like its gone and if theres water in ur car its coming from there. Im just assuming here as there is limited info on problems.Think the windscreen is letting water in
I really dont mean to sound sarcastic but... if you knew it had these problems... why did you buy it? If you didnt give the car a thorough going over first then you only really have yourself to blame.
Though id say its worth fixing. Once you own a polo you dont go back. Theyre s**t hot, and i onyl have an 8v... and now im going to stop typing begfore i cry at the realisation that i have no MOT....
Avinitlarge
Avinitlarge
Bought it from Flee bay, From the description it sounded ok, They said the expansion tank was cracked, Thats why it was loosing water. I had someone collect it so never saw the car until it got to me. The car isnt actually mine, Its my other halves, She was insistant the she wanted it.LeMeph wrote:I really dont mean to sound sarcastic but... if you knew it had these problems... why did you buy it? If you didnt give the car a thorough going over first then you only really have yourself to blame.![]()
Though id say its worth fixing. Once you own a polo you dont go back. Theyre **** hot, and i onyl have an 8v... and now im going to stop typing begfore i cry at the realisation that i have no MOT....
Re: My 1st Polo
When read this I thought how comesAvinitlarge wrote:Just bought a P reg Polo, 1.4 16V. Its Possible the worse thing Ive ever done to be honest.
Guess your problems are from not viewing the car before purchase, especially from fleebay! So you've bought a lemon but get it checked out by a garage if you can't see where the waters leaking from. The windows however are a common problem and mechanisms can be found at scrappies.
Avinitlarge
Re: My 1st Polo
I actually work at a BMW garage, One of the mechanics said it could be a number of things, But I personally think its the head gasketNOZ wrote:When read this I thought how comesAvinitlarge wrote:Just bought a P reg Polo, 1.4 16V. Its Possible the worse thing Ive ever done to be honest.![]()
cos 16v's are some pretty sweet toys for what they are.
Avinitlarge
Well, A little news, Decided to have a look at it before setting it on fire
Drivers side electric window doesnt work - The wiring between the A pillar and door has broken
Loads of travel in the brake pedal - Wheel bearing collasped
Heater doesnt blow warm, Never mind hot - Water pump and thermostat knackered
Avinitlarge
Avinitlarge
Done a little more work on it, Fitted a toad alarm, Quad lights, Green indicators and badgeless grille. Repaired the glove box whilst it was out, Also repaired the rear wiper motor. Its slowly getting there, Just need to get it down to work and and replace the wing then into the body shop, Having the bumpers, Roof, Mirrors, headlight surrounds and wing painted
Avinitlarge
Avinitlarge
Yay, Its finally on the road. Just need to adjust the headlights. Took it out tonight, It seems reasonable nippy. Im not sure if the engine is goosed though, I gave it a good thrashing, There was quite a bit of smoke, Might be because it has been stood for a couple of months though, I hope it isnt the rings
