I was wondering whats the best way to clean the seats my passenger seat has a drink spilt on it and its marked it, now my mates have said about steam cleaning but ive heard this dulls the colour withing the fabric?
Im also asking because i might be able to snap up a 6n2 but again has some marks on that id like to clean up and make mint...
Cleaning interiors...
Dont use to much water when mixed with soap or detergent as it will get deeply absorbed, then use a wet cloth which should remove or spread the chemicals used without the cause of drying up patched, its all gently and carefully done not in huge splash wods which I find best, without causing any wet drying up patches after, if that makes sense.
- Tim_GTi
- Post Whore
Buy Autoglym hi foam interior. It's spray foam, and really good. Another good one is from turtle wax, which comes with a top mounted brush. both good products.
Bascially you spray it on and brush it in, then wait for it to dry. you often need to wash the whole seat at a time, for you'll notice where you have and have not cleaned
