Cleaning interiors...
Josh_polo
Post by Josh_polo »
I was wondering whats the best way to clean the seats my passenger seat has a drink spilt on it and its marked it, now my mates have said about steam cleaning but ive heard this dulls the colour withing the fabric?
Im also asking because i might be able to snap up a 6n2 but again has some marks on that id like to clean up and make mint...
polo-sib
Post by polo-sib »
Steam cleaning shouldn't dull the seats should do quite the opposite, either that or try water with washing up liquid or a washing detergent(eg, aerial) in a mild dosage.
Josh_polo
Post by Josh_polo »
polo-sib wrote:Steam cleaning shouldn't dull the seats should do quite the opposite, either that or try water with washing up liquid or a washing detergent(eg, aerial) in a mild dosage.
Only thing ive thought about it how would i go about drying it with out getting drying stains?
polo-sib
Post by polo-sib »
Dont use to much water when mixed with soap or detergent as it will get deeply absorbed, then use a wet cloth which should remove or spread the chemicals used without the cause of drying up patched, its all gently and carefully done not in huge splash wods which I find best, without causing any wet drying up patches after, if that makes sense.
Josh_polo
Post by Josh_polo »
Ill prob bat with steam cleaning, just wonder where or how much a steam clean/cleaner will cost?
polo-sib
Post by polo-sib »
Josh_polo wrote:Ill prob bat with steam cleaning, just wonder where or how much a steam clean/cleaner will cost?
Check ebay or contact Alex Perkins, think he purchased one recently, his your best bet :D
Mike
Post by Mike »
couple of options, buy a George carpet cleaner, like i did had to do, bought mine for doing the house carpets, or drive over to me and i'll do them for you. i'm in Aldershot.
Tim_GTi
Post Whore
Post by Tim_GTi »
Buy Autoglym hi foam interior. It's spray foam, and really good. Another good one is from turtle wax, which comes with a top mounted brush. both good products.
Bascially you spray it on and brush it in, then wait for it to dry. you often need to wash the whole seat at a time, for you'll notice where you have and have not cleaned
