car stereo
Harnz
car stereo
Post by Harnz »
has anyone changed there stereo to a single din after market one. if so the facia(facial adaptor) you used to change the stereo from double din to single, where did you getit from as i need one is there a site orany places i cant gt it from. thanks
GTi_dan
Post by GTi_dan »
Hi Mate,
I've changed my stereo to a single DIN unit.
In (some) 9N Polo's 2003ish had single DIN stereos fitted with a little cubby box/shelf fitted underneath... These are the best to use as look spot on and match your interior.
I got mine from my VW dealer for around £20quid ish.
However don't make the same mistake that me/my dealer done....
They come in 2parts which order seperately
#1 The plastic dash cubby box itself
#2 A little rubber mat that fits inside
To fit.... Just push in and it clips together perfectly!
Or maybe try vagparts, search "Din Size dash cubby box" ????
Hope that helps!
Harnz
Post by Harnz »
yh that helps alot thanks i fink i saw it on there site so that jus means i need that cubby box and thats all and then my single din stereo will fit?
GTi_dan
Post by GTi_dan »
Yep that's all you'll need to make it Physically fit. :wink:
You may already know this, but you'll also need the following to make the aftermarket headunit work.....
1# CAN-BUS --> ISO wiring harness
2# Antenna Amplifier (as ariel amp is lost when you remove the OEM unit)
See link...
http://www.bluespot.co.uk/install/show_model.asp?id=297
Go to very bottom of page to PART REF: 7607621175 .... This is what you need and as a bonus also comes with the Antenna Amp (the silver cylinder looking thing) included in the kit.
It's pretty easy to fit.... I done mine myself.
Good Luck
Dan
Harnz
Post by Harnz »
thats been a very big help mate thanks agen :D
GTi_dan
Post by GTi_dan »
my pleasure :D
whitegtipolo
Post by whitegtipolo »
i fit one too! :lol:
Rich_T
Post by Rich_T »
whats the bottom tray whitepolo??? just a cd holder?
whitegtipolo
yes, got it from my astra quite handy for your popular CDs LOL and perfect for the gap! 8)
Rich_T
Post by Rich_T »
so that will be for your classical musical collection then?? :wink:
daa709
Post by daa709 »
Might have a can-bus adaptor lurking somewhere since I got rid of that double-din pioneer car-system-of-destiny..
Will check and let you guys tomorrow if anyone wants it for cheap.
whitegtipolo
you can just wire it direct to an ign feed etc and do wawy with can bus thats what i did alot cheaper too, any stereo place will show you wat to do! the amp converter thing is only for AM and i dont listen to AM so i was not bothered!FM works fine!
Harnz
Post by Harnz »
ok i just need somthing that will make my double din slot become a din slot so i can fit my stereo. preferably something with a space at the bottom so i can put things there. if theres chaper alternatives im intrested aslong as they work properly lol
Harnz
Post by Harnz »
whitegtipolo wrote:i fit one too! :lol:
something like yours but preferably with the space were your cd thing is empty so i can put something there. is that a CD holder or disc changer by the way thats quite a smart and in expensive mod 8)
whitegtipolo
its just a cd holder :D filled the void and cost nothing as was out of my astra!
