as far as im aware mate there is a sticker on the inside of you boot. Basically open the boot and stick your head into the boot as if your looking between your legs. There should be a sticker with loads of numbers and letters on it. The engine and the gearbox should be on this. Its usually 3 letters. Someone will correct me if im wrong.
Any idea about which model polo it came off, 1.0, 1.4CL, 1.6, 16v?
someone may be able to help out on which box goes with the car it came from to help out although people do sometimes put a box from another model into theirs.
Not sure if them numbers are the part number, which I doubt. Would've thought the box code would be stamped on too!
