are they all the same size and fit?
side repeaters??? question on fitting from other vw
would the mrk5 polo or 2001 passat clear side repeaters fit a mrk4 polo 1998??
I did this job 2wks ago on my 97 6n.Kerley is right they are push on a 97 6n but i'm not sure about other years. you might have to adapt the bulb socket thou as the ones i got from VAG were slightly different.
sorry the pics abit big but its night over here so cant take a new one.thought if i blew this up you might just see em
lyndarthemerciless
Has anyone more info about fitting 6n2 side repeaters to a 6n? My current side repeaters are push/pull fitment - I'm wondering if I can just swap in some 6n2 repeaters once I use 6n2 bulbholders? Or are the connectors or anything also different..?I did this job 2wks ago on my 97 6n.Kerley is right they are push on a 97 6n but i'm not sure about other years. you might have to adapt the bulb socket thou as the ones i got from VAG were slightly different.
This is wrecking my head so any info would be mucho appreciated!
