anyone know the offset for 18" not to catch
yorks GT TDI
- Sponsor
looking at some 18" alloys does anyone what the offset so they dont rub as im going to lower it
38 as standard is fine up to a 7.5j wheel as more than that it will most likely foul the suspension leg, if your using an 8j wheel use et35, but if your going low low, expect rubbing still, more so on the front and on full lock
also, you need to be using a 213x35x18 tyre
for more info, pm or speak to whitegtipolo as he's running 18" monzas
- whitegtipolo
18" Just fit, mine are 8j with 35mm offset, fit fine on standard suspension , when i lowered on coilovers though had to get 3mm spacers for the front as the rim/tyre nearly touched the adj ring on the front coilovers, still room under the arch too, the front arches are pretty easy to manipulate , tuck ya slash guard out of the way and fold the flaps of the arch right back too! Mine never catches on the front , just seems to catch on the back on the o/s but i think thats due to some axle alignment issues! Its going to be checked at Awsome as soon as i get round to doing my n/s front top mount which has gone!! Hope this helps any more info PM me!
- whitegtipolo
