anyone know the offset for 18" not to catch
yorks GT TDI
Sponsor
Post by yorks GT TDI »
looking at some 18" alloys does anyone what the offset so they dont rub as im going to lower it
Tim_GTi
Post Whore
Post by Tim_GTi »
The offset of what? A recommended offset that doesn't rub? It would also depends alot on the width of the alloy and the size width and profile of the tyre, but I would imagine anything around 30-40, don't quote me though,
Jeff GTi
Post by Jeff GTi »
38 as standard is fine up to a 7.5j wheel as more than that it will most likely foul the suspension leg, if your using an 8j wheel use et35, but if your going low low, expect rubbing still, more so on the front and on full lock
also, you need to be using a 213x35x18 tyre
for more info, pm or speak to whitegtipolo as he's running 18" monzas
whitegtipolo
Post by whitegtipolo »
18" Just fit, mine are 8j with 35mm offset, fit fine on standard suspension , when i lowered on coilovers though had to get 3mm spacers for the front as the rim/tyre nearly touched the adj ring on the front coilovers, still room under the arch too, the front arches are pretty easy to manipulate , tuck ya slash guard out of the way and fold the flaps of the arch right back too! Mine never catches on the front , just seems to catch on the back on the o/s but i think thats due to some axle alignment issues! Its going to be checked at Awsome as soon as i get round to doing my n/s front top mount which has gone!! Hope this helps any more info PM me! :P
Jeff GTi
Post by Jeff GTi »
how has your front top mount gone?????????
andy947
Post by andy947 »
Jeff GTi wrote:how has your front top mount gone?????????
Cos they are a known weak point and a crap design!!!
Once you start battering them with overly stiff coilovers they soon die.
flyfs6
Post by flyfs6 »
How do you tell its gone? :oops:
whitegtipolo
Well its cos i dropped it when building my coilies up and it split apart, so cos i didnt have a new one to hand LOL , i just put it back together, i knew it would go eventually, it clunks the spring when turning etc cos the the bearing is shot! :P
flyfs6
Post by flyfs6 »
Cool. I think mine might be gone, but it maybe something else which my car is in at VW for at the moment.
Tim_GTi
Post Whore
Post by Tim_GTi »
Mine clunk like there's no tomorrow!
