An i was thinking that myself. Although the ones i am looking at have a lot of water leakage in the lacquer and dont really have the funds for a refurb at the min
Ano id like to. But gona get a price for respray after removing my bumpstrips. drivers side has two different shades. and bottom half is like a lacquer. Tried everything, so looks like respray is the last resort or else stick them bak on.
no idea if they will fit. you will have to check the pcd. should be 4x100. then theres the center bore of the rim to consider. hat car are they coming off off?
Not sure but i'd imagine them Estorils come in one fitment. All VW rims have 57.1mm bore so thats not a problem. if they came off a mk2 then they defo fit as both the mk2 and a 6n have the same fitment.
Won these the other day. Currently awaiting the delivery but they from germany so may be a while lol. Trying to start sourcing tyres for them. Any recomendations?
You'r ok with 195/45/15 but if you want stretch then go for something with a smaller width. As they're ET35 you may want to add spacers to the front and back to make them looks even better. Possibly 10mm at the front and 15/20mm at the back.
