The knocking got worse and worse. Steering wheel got REALLY shaky. I was panicing and rang Alex P when i left the A1 going onto the A47 and he said it might be my uspension (I had recently fitted my strut brace).
So i thought right well i'll look at it when i get to Haris's house as its not that far away. Then about 5 to 10 minutes later the shaking got supidly bad. I then put my hazzards on. 2 seconds later i heard a huge clunk and plumes of smoke out of my rear view mirror. I let the car drift to a stop as i wasnt swerving thankfully!
I ended up stuck on the A47 on a busy Sunday! Two guys tried helping my move it but it wouldnt budge. The guy said my suspension must have collapsed! So i opened my bonnet and everything was fine. So i then thought that it might have came lose at the bottom near the hub.
I was then mortified when the RAC guy tried taking my wheel off............................
It turns out 3 of the 4 wheel bolts holding my wheel on had slowly worked their way off hence the wheel buckling under the weight.
It turns out i need a new rim, as the holes where the bolts go through have ovaled out and a new tyre at least. The car went into the garage this afternoon and ill know the damage if any tomorrow when i ring them up.
Heres some pics
The skid mark left by my tyre right in the distance.....
And where i ended up
Random pics
The damage (not the best shots, will get some more when the wheel is off. It took a shard out of my wheel and it wedged onto the caliper
All i can say is meh
