Turbo conversion
Discuss Engine, Gearbox and Exhaust
KarlM
Turbo conversion
Post by KarlM »
Hi all,
I can pick up a G40 block for my car without the charger
After pricing the charger up (and trying to find one!) i've decided to replace it with a turbo. So i need a bit of help.
I need to source:
A metal head gasket
a smallish turbo
a custom manifold to bolt the turbo to.
Can anyone help or give advice on this conversion?
cheers
EddyH
Post by EddyH »
You're also gonna need a custom downpipe, intercooler, custom pipework, wastegate controller, DV and some kind of software.
The K03S as found on the newer 1.8T would probably be a suitable unit and can be picked used for under £200.
KarlM
Post by KarlM »
Nice.
Anyone know if JBS would be capable of knocking those bits up?
polo2k
Post by polo2k »
martin can do a new uprated one if you cross his palm with gold
KarlM
Post by KarlM »
new uprated what? the turbo?
ask him for a price will you.
Me a Pollock are going to start on the engine next week when i change the suspension
polo2k
Post by polo2k »
ill try and remember when i speak to him next
J-O
Post by J-O »
i know rothe motorsport makes the exhaus manifold for Polos...they should have it for G40...
hardhitter
Moderator
Post by hardhitter »
You can get new G40 chargers from germany for about 500 quid, have a look on pvw classifieds.
hayesey
Post by hayesey »
No need for a metal head gasket by the way. A G40 one can cope with well over a bar of boost. Don't know the exact limit but plenty of people with G40s (myself included) run a smidge over a bar with no problems.
You mentioned somewhere else about needing it to lower the compression ratio as well, theres no need for that as a G40 engine already has a lowered ratio using a larger bowl in the piston crowns.
You'd only need to do that if you were fitting a turbo to a previously naturally-aspirated engine.
KarlM
Post by KarlM »
right, just found out about a compay called Roth Motorsport that do turbo conversion kits for G40s. It includes all pipework and a K03 turbo.
anyone heard anything about them?
