Engine swap in 1996 mkIV
misiokicio
Post by misiokicio »
Hi guys!
I`m new in here and just need some advice.
My polo is 1996 1.0 engine aev.
Have a car breakdown last week and need to get a new engine(Scrap yard)
Is there a problem to fit in a 1.3 or 1.4 engine in this car??
I know i need a new ECU but is there anything else what will not fit??
Please help me.
Want to buy it on friday
Naz
Post by Naz »
try and get an engine and gearbox together
also loom and clocks will make the job easier if you going to get a different engoine to what you originally had-
misiokicio
thanks for your answer.
Is the ECU gonna be a problem?
Sorry for asking but not really know what is taht loom?
thanks
Naz
Post by Naz »
loom- Engine wiring loom connects all your electrics- clocks etc to the engine
Not sure if you could get away using your 1.0 one with a diff engine-
and if you change to a diff size engine you will most probably need the ecu from it
Try and get everything from the same car if possible-
Isnt it easier to get your engine repaired ? whats wrong with it exactly?
Josh_polo
Post by Josh_polo »
Surley youll need bigger breaks to?
NOZ
Post by NOZ »
its much easier to get a direct replacement reather then a larger lump transplanted. I would guess you'd need the engine, loom, ECU, gearbox (probably not necessary). If the 1.4 has larger brakes then 1.0's then you'd need them changed for better braking.
LeMeph
Post by LeMeph »
on a 6N everythings pretty much the same as far as im aware. yeh youll need the ECU and wiring loom. leave the gearbox from the 1.0L on it will probably a little bit faster if anything! no point spending more then you need to afterall.
If you want to make the whole job easier try and get an engine that is off the same year. The earlier engines seem to be better so get a P reg if you can. Cuts out all the annoying sensors VW started chucking on absolutely bloody everything!
MiWi
Post by MiWi »
I have both a 1,0 and a 1,4 16V.
The only differens between them is that the 16v-version were sold with ventilated front discs.
The regular 1,4-version are solid and the brakes are identical with the 1-liter.
