Thinkin of goin back to stage one
KennyPOLO_Gti
Post by KennyPOLO_Gti »
Had Stage two on my car for a month now and am not too inpressed with it. Car doesnt seem a torquey as when i had stage one. 1st and 2nd gear seem fine but 3rd, 4th and 5th seem a lot slower, dont really feel my turbo kicking in or anythin, just seems very flat. Also my car before dont 145ish (on a track) very easy but now its struggles to go past 120!!! :?
Only thing I have done is Stage two and got the 2.5" downpipe and sport cat on the same day and thats when its began to feel very flat :(
more-bhp
Post by more-bhp »
Problem with your TIP / N75 Install ?????
Further exhaust/ intercooling mods required ???
Stage 2 will equal more boost (+more by N75J), more fuel, more ign advance - without the full exhaust and intercooling.... EGTs will go sky high.... charge intake temp goes too high.... ignition correction goes too high.... ecu just pulls it all back till its happy again... so performance can go worse not better....
But I'd check all the pipes, etc, etc..... you need someone to read the ecu to check for errors and look at the long term fuelling and ignition correction....
J
KennyPOLO_Gti
Not the TIP or N75J coz was having this problem just after the remap and exhaust which were both donre on the same day. Still waiting on my APR DV to come, ( guy havin problemn with APR or somethin) anyway been promised it will be here next week, so hopefully that makes some difference cos i can feel the car totally dying between the gears and taking a few seconds for the turbo to start boosting up again with the standard DV. TBH i think it really needs the FMIC which I cant afford the now so am thinkin about goin back to stage 1 :(
* Do 1.8T 225bhp run the same DV as the 150bhp???
more-bhp
Post by more-bhp »
Yes TT225 runs same Bosch DV, although there are different revisions as they have been improved upon over the years... the Bosch DV manages 1.5 bar in a chipped TT .... no problem...
I only use the Forge FMCL007P because I like the shineyness.... I have swapped back to the 710N before... performance just the same...
more-bhp
Post by more-bhp »
perhaps the sports cat you got is not good enough... good sports cat is very expensive....
Surely its cheaper for you to get some proper diagnostics done than go back to stage 1...
whitegtipolo
Post by whitegtipolo »
weird i think its hitting limp mode in the higher gears mine used to when i tried a atmosphere dump valve only on mway :? Dunno i had a 2.5" with no cat and mine feels to hold boost longer now and is smoother does 155mph LOL, might be the CAT is it 2.5" , i heard the standard cat is just as good if removed and 2.5" pipes welded on each end if you get me try that! Other than that id take it back to APR and say your not happy and get em to check it or re flash it maybe! :roll: My airflow meter went a few weeks ago might be that too! :?
KennyPOLO_Gti
Theres not even anywhere near me that i can get RR. really pissin me off. Dont wanna take ma cat out cos last time i done that i got a engine managment light on! :(
Jeff GTi
Post by Jeff GTi »
its the charge and intake temps kenny, to run a stage 2 car you really should be running the front mount too
mine runs so well with similar mods to yours and absolutely flies, no holding back at all
whitegtipolo
hows it running now its really cold take it out early one morning or at eve and i bet it flies , mine is mental when its like this all frosty , took it out late on last night after my shift , what a beast! Just shows the forge cooler is needed! :wink:
KennyPOLO_Gti
Yeah thats why am thinkin about goin to get stage one again, only thing is its on the other side of the country!! Thinkin of goin for another remap, up in Glasgow I can get REVO or Custom Code. Anyone had any experience with any of these two??? :?
whitegtipolo
get revo nice and agressive!! :lol:
more-bhp
Post by more-bhp »
Kenny,
Mine had been revo'd before I got it.... ran ok... no problems... not that aggressive...fairly smooth...just slight boost spike at the usual 3200rpm..
Bear in mind that Revo was born from APR... so that will give you the idea of how it will feel... ie.. not much different than the APR you had ;-)
Custom Code ... more American written stuff.
Also bear in mind now APR have been near the ECU it might have to come out for tuning next time because they will have changed the access key for OBD programming...
So perhaps consider this ???
Remove the brain and send to me.. and choose...
1. Revo style ;-)
2. German Style - AGRESSIVE - Like Whitegtipolo
3. More-BHP style - Smooth - Like many others on here....
Just for the cost of postage ....
And dont worry about the anti-tamper ecu case - I tell you how to remove it.
J
KennyPOLO_Gti
I would mate, only thing is I need my car everyday ( hence I have clocked 32K miles already!!) if you were a bit closer i would travel to get it done! Not plannin any trips up my way!? :lol:
