I would mount the amp elsewhere though. What about a false floor in the boot? It wouldn't get damaged under there.
interior updates and colour coding
Petrol_Head
stevie boy
- Tim_GTi
- Post Whore
Because it couldn't be anymore in way, unless it was on the dash or you were sitting on it!!
Once tweaked a few times, your amp should be good to go. You shouldn't have to perform on-the-fly alterations to it, that should be done through the headunit.
Totally up to you where you place it though. I'm just saying there's many a better place!
L'enfant terrible
I noticed your headlamp control unit has two dials where my Polo (don't know about others) only has one. Did yours only have one before? If so do you just ignore the second one (headlight adjustment or whatever it is)?stevie boy wrote:for the light controls i got another unit from a SEAT arosa.they light up red as in standard form and are a straight swap
for the heater controls you need to remove the black plastic front.inside you'll see the green plastic that lights up for the heater functions.swap this with the same part,using the same process,with one from an arosa or ibiza.job done.easey peasey
stevie boy
stevie boy
