De-Badge
1st_polo
De-Badge
Post by 1st_polo »
Im going to take my badges off the back of my car tomoz and just leave the Volkswagen one.
Wat would be the best wat to romove them and how they held on
Cheers guys
Jordan
pip_polo
Post by pip_polo »
heat them up with hot water/hairdryer
then peel them off. or use fishing line behint badges
if your lucky it will bring most the glue off.
if not use wd40 or something to take the black glue off.
search in diy guides for it in more detail. think i did it ages ago.
Tim_GTi
Post Whore
Post by Tim_GTi »
Heating them up helps, but is not essential.
They're stuck on with sticky foam, so just cut it off with a guitar string/fishing wire.
Then use some WD40 or a cleaning product of your choice (AG intense bug remover is good) to get the residue off.
1st_polo
Post by 1st_polo »
Cheers guys that helps alot
Also is it hard to take the gear knob off so i can change it
cheers
jordan
Tim_GTi
Post Whore
Post by Tim_GTi »
If it's anything like the 6n2 (pretty sure it's very close), just gently unclip all the plastic tabs aroud the edge, then flip off the metal clip on the underside.
1st_polo
Post by 1st_polo »
Cand i take the Vw one off aswell or is that clipped on and would i have to get that smoothed out?
Jordan
Tim_GTi
Post Whore
Post by Tim_GTi »
not sure on the 6N in terms of clips, there's an indent though, so you'd have to get that smoothed out.
vw-po-low
Post by vw-po-low »
The 6N has two small sections that clip into the boot as well as the glue foam. I just gave mine a tug.. all the glue stayed on the badge. Though mine is currenly super glued on now that its black.
stevan
Post by stevan »
Take your time!!
